noelex
These are the commercial Tytec blocks.
They have a Dyneema soft shackle attachment with a leather cover instead of the more traditional stainless steel attachment.
Reducing dissimilar metal contact is important for an aluminium boat. We have reduced the amount of stainless by welding items such as the jib and stailsail track to the deck instead of bolting them on with dozens of fastenings. This also eliminates the chance of leaks, and the track serves as an additional above deck stringer, strengthening the whole structure.
The Dyneema loop also has the advantage that it is quiet. When sleeping, a banging block can keep the off watch crew awake. One of the keys to getting adequate rest offshore is reducing noise. The thick insulation fitted under the deck muffles most sounds, but a banging block can wake the dead.
The Tytec blocks are very well made with proper metal cheeks instead of plastic. They also have very high SWL for their size.
The drawback is the Dyneema straps will need periodic replacement due to chafe and UV perhaps so it helps to marry a Mermaid who can also make Dyneema soft shackles
We have tried hard to reduce the maintenance and periodic replacement of components on this boat. Attaching blocks with Dyneema is more along the racing philosophy of reducing weight. At first glance it appears against the ethos of bullet proof and reliable, but I think with an aluminium boat it is a sensible compromise.
In addition to the tracks for the genoa and staysail, the toerail on top of the bulwark is immensely strong. As well, there is a multitude of aluminium handrails and pad eyes scattered around the deck. This allows multiple attachment points for blocks with a Dyneema loop attachment, permitting the ideal sheeting angle.
The Tytec blocs are beautiful, and lightweight for the strength achieved, but not as robust the custom designed KM hardware. Sadly It is not cost effective to custom produce these smaller blocks
