Paul1972stevens
It has rust and all sorts or shit in there what's the best way to clean it?
Assuming you only have access via the filler, or perhaps the level switch fitting, I would drain down as far as possible, then use an endoscope camera to carry out an inspection, I would then attach this a few inches up from the end of a length of plastic tube attached to a small electric pump via a separator filter (e.g. Baldwin) to suck out the crud. Might need to change the element, and add some more fuel once filtered to keep the crud loose, then work your way around the base of the tank.
Once you have as much out as you can get, top up with a decent fuel additive such as Fuelset or Grotamar.
My homemade portable fuel polisher is shown on my blogsite (below) - improvements page.
Well, the pain is still with me! I still have crud in the bottom of the tank, despite hours and hours poking towelling rages in mopping-up and sucking-out with a vacuum pump. The endoscope views a tiny bit, but once "bent into the tank" is uncontrollable. Can't make out a thing.
And I've just been told I may well have a baffle, which stops me getting to the far end anyway.
Only recommendation I have been given is to mop as much up as possible, fill with fuel (diesel, I presume?), go for a bumpy spin around to slosh the crud up and KEEP MONITORING/CHANGING your fuel filters. Slightest sound of the engine wavering, stop, drain the fuel lines, check and change the filter again - and keep repeating until no crud comes into the filters.
Sorry to be a doom-monger - I wish you well.
This coming winter I'll remove the tank, fit an inspection hatch and replace the tank where I can easily get at it!
Good luck.
How big were your tanks - we had these on Type 42 Destroyers and similar size Frigates with water displaced fuel tanks - rated in tonnes per hour, mostly 3 phase powered ?I used to run boats in some pretty crappy areas in South America that we ran Alfa Laval centrifuges before the day tanks. They are a couple of grand a piece, but work well when offshore for weeks on end.
With 10,000 miles range no need to RAS then !Not as big as your beggers.
No, just normal ones on fishing boat, 6/8 tonnes in each tanks. 6 tanks on each boat. The big bugger was close in size to yours, 10,000 mile range at cruise.
Oh yes and a Racor 500 or pattern version from ebay, or if your engines are a bit bigger of for serious contamination the 900 series with magnetic bug killers. I have Pure Fuels FMIS08 units fitted to engine engine supply directly fitted to the Racor pattern 900 pre-filters. My fuel systems haven't missed a beat since these improvements, including the low level polishing connections, were installed.
You really really need to get inside tank to take look.No amount of filtering or refiltering/ changing of filters is going to prevent problem reoccuring if tank is corroded internally.It will merely put off the day when you are out somewhere a bit lumpy and enough scale/gunge will dislodge to block filters.It has rust and all sorts or shit in there what's the best way to clean it?
