Best Glue For Wood
lw395
16 May 2007
For mending large bits of outdoor woodwork, I'd use an exterior PVA glue.
Much more sensible cost for big jobs.
The 'Instant Nails' stuff from Toolstation is also very useful and cost effective, despite bearing no resemblance to either 'instant' or 'nails'.
Mending a gate is different from building a Merlin Rocket.
Refueler
13 Sep 2008
Far away from hooray henrys
I always find it interesting that you can have a glue that is stronger than the material it is joining - but the repair often fails before the material ......
On a Gate or similar - I would usually look at inserting a bridging piece or dowel across the joint to increase the strength of joint. You see many people make the mistake of screwing metal plates ... but they soon fail and are loose. Better a wood dowel inside the joint - which not only gives mechanical strength but also increases glued area into the good material.
C08
8 Feb 2013
Yes I had planned to dowel as well. Having great difficulty finding 100mm x50mm,it seems industry standard 4x2 ia about 95mm x45mm planed, even sawn timber is not normally actually 100x50. I will probably have to have a bigger section planed down...at a cost.
Old Harry
29 Sep 2017
All timber is nominal sawn dims, 6mm is remover to plane it to PAR
DownWest
25 Dec 2007
S.W. France
An electric planer is peanuts at B&Q, then can be used to assult wood later on. Far cheaper than asking for it to be done.
C08
8 Feb 2013
I have my dowels, Titebond but still no wood. Still a full time job trying to get a food delivery
