mikejakes
New Member
I've got a raw water cooled Volvo 2003 and it's been overheating due to a build-up of silty sediment in the block. A mechanic has used Spirit of Salts (hydrochloric acid) to try to shift what he described as a slimy grey sludge as seen through the block drain hole at the back of the motor, starboard side but I'd like to flush the block a few more times to try to ensure that it's completely clear. As I really don't fancy the alternative of removing and strippping the engine for a manual clear-out, what has been used successfully to get rid of crud like this from the block? (For info, I have confirmed that the water pump and thermostat are working correctly and that the water distribution pipe, exhaust elbow and associated external pipework are all clear). I suspect that converting the engine to fresh water cooling will be cost-prohibitive.
Also, can anyone recommend a raw water strainer that will still allow an appropriate bulk flow of raw water yet filter out particles smaller than the footballs my existing one lets through?
Thanks in Advance
Mike
Thanks in Advance
Mike
