Bertram 25 - project / loads of pictures
jointventureII
30 Jan 2002
Genoa Italy
So, in November 2020 I went ahead and purchased a battered, neglected Bertram 25 which had been left to rot.
She was a mess, a total mess. I went for a sea trial and found the following wasn't working:
3 bilge pumps
Upper fly position (neither the steering or throttle or changeover system)
Nav lights
Interior lights
Wipers
Toilet
Spotlight
Instruments / dials (only the temp gauge seemed to work - oil pressure, rev counter, trim gauges on both helm stations showed no signs of life)
Water pump
Gas stove
In fact the only things operative were the lower steering (albeit very loosely) and the lower throttle, though this was very difficult to put into gear as it was so stiff it must have been close to seizing. However sea trial day was a stiff force 5 and this little boat just ploughed through it. I have never been so impressed, apart from a trip on a Botnia Targa a few years ago.
She was loaded onto a truck and moved from Marseille to Italy where I live.
Got her into a yard and set to work: the engine needed lifting out as it was a ball of rust. Steering arm rusted to bits, which meant the steering seal had gone.
Doesn't look too bad below, but from mid-engine down it was a total mess.
Once pulled, this was what awaited me...! There was a 10mm layer of sludge in the central compartment which even brake disc cleaner struggled to shift but after many hours, lots of swearing and about 40 cups of tea, it started to clean up.
And then a lot of grinding, chipping, sanding and general fun with the engine.....
I took off the turbo, oil pipes feeding the turbo, intercooler, heat exchanger, engine mounts, wastegate, starter motor, alternator and dealt with each one individually.
Flash forward a few months and suddenly it's starting to look better....a fresh coat of danboline, the transom assembly plate all repainted, new freshwater inlet valve added, pipes and cables either cleaned or replaced.
The extremely satisfying thing about this project was that I managed to save an awful lot just by cleaning, greasing etc. however the turbo was dead as was the riser, so I had to get hold of new ones.
All the removed parts primed and painted, ready to go back on with the new turbo and riser.....:
And then installed, having primed and repainted the engine itself....
To try to save the transom assembly, I used the JR Marine kit, a new steering lever, and a stainless steel steering pin to try to save it, modified to include a grease point as recommended by Spannerman. I didn't know at the time but my transom assembly was too far gone and this didn't work, looking back I should have probably realised this with the tonnes of rust in / around that area, but it looked like the steering seal sat well so I gambled and went for it.
The only thing I didn't do myself, was change the cone clutch in the sterndrive, which (having dismantled the upper half of the leg as much as I dared) I'd deduced to be a worn clutch. I don't have the specialist tools required to do this job, Mercruiser produce an awful lot of specific tools which would have cost a fortune and an error would have destroyed the drive, so I spent €400 on getting the leg serviced and a new cone clutch put in. Sourcing the cone clutch proved extremely difficult as it's the old, no-longer-available style, discontinued in around 2000 (?). I managed to source one in the US and had it sent over.
During this time I also changed the flybridge throttle cable, the shift cable for the sterndrive, the changeover plate (to switch between the upper and lower helms), the trim pump mount (to a stainless one) and the float switches.
And then, in March 2021, after 5 months out, she was back in.
Within a month, there was a slow drip leak into the bilge from the sterndrive transom assembly and I knew my gamble hadn't paid off. This continued to grow and consequently I knew I needed to replace it. Which meant engine out all over again. In the mean time sorted the electronics out (nav lights, instruments, water pump, gas stove, rewired loads of things, added some speakers) and gave the dashboard / dials a spruce up.
Flash forward to July 2022 and the boat is lifted again. This time, as well as changing the transom assembly, I planned to strip the hull back to gelcoat and epoxy coat it. Cue a few heart attacks.
Firstly when the transom seemed to just fall apart. This boat was originally built with twin petrol sterndrives. When the boat was converted to a single engine, the people that carried out the work did a great job of closing the holes and glassing, but not such a good job of covering them with gelcoat or whatever it was. At this point I stripped it all back and had a surveyor test for moisture. It came up slightly high but nothing crazy, and as the boat was about to sit in 35°c heat for 2 months, I was confident this wouldn't be a problem.
Whilst the transom was drying out, it was onwards with the stripping of the hull which started out like this:
And this is it nearly stripped, at this point there are the areas just about the waterline to remove but it's 95% done. This was around 60 hours of the most horrendous work I've ever done, and the transom is still to sort out.
So once it was all removed, the epoxy coating was ready to go on. I used Boero Delta followed by Boero Defender (2 coats) for a total of 3. I didn't do the transom at this point as I needed to level it out first.
By now, it was near the end of September and time to move inside. In reality I could have gotten away with more time outside but after 3 months sat in the baking heat, I was confident the transom was totally dry and thus ready for repair. This was another extremely lengthy process using thickened resin, followed by Awlfair (the red / pink stuff) followed by another extremely fine filler by Boero. It took a month alone.
Below is just after another round of sanding before the next application of filler. It was literally endless and I decided I had to stop eventually as this area is underneath the swim platform, so not really visible, but also that I would probably never be totally satisfied that it was perfectly flat despite using the 1 metre long ruler, shining light on it to see shadows and various other weird and wonderful methods.
In the mean time I'd sourced a 2nd hand transom assembly, for a decent price, that had hardly been used. It was from a superyacht tender that was kept out of the water. This was perfect so once the transom was covered with epoxy, I set about installing the new transom assembly. The Mercruiser manuals say to simply put in the foam seal, torque it and and that'll do but I couldn't resist putting a thin bead of underwater silicone around the edge. I also installed the Spannerman grease point, as I'd done the last time, and changed the steering pin for the stainless one.
The engine could now go back in, and all the extras that come with it - attaching all the hoses, cables, gear lever setting, connect the steering and replacing the side panelling. Just the engine alignment alone took a good few hours, to get it absolutely perfectly straight. This is done using a specially manufactured stainless bar that slots into the gimbal ring and is then very lightly pushed into the coupler - the manual says it should be possible to slide the bar (which weighs a good few kgs itself) using 2 fingers to push.
After the engine was properly aligned, the leg went back on. This included changing the oil, then sanding it down, primer and antifoul.
Then a day or two later, she was ready to go back in again, after a 2nd 6 month yard stint. I won't lie, this time I was quite nervous about having forgotten something and plenty of nightmare scenarios ran through my head.....peering into the engine bay with the torch and watching water flood in, oil seeping into the sea, something not working. But it went well and the boat hit 26.5 knots on a sea trial with no leaks, strange noises or smells.
I've got to clean the teak border and put on some SEMCO before I'll be taking pictures of the other end!
Portofino
10 Apr 2011
Boat- Western Med
I had the opportunity to see this boat with the Op when he kindly Taxied us about the marina .
Very splendid indeed .Just looks right .Dick Bertram knew his stuff .
jointventureII
30 Jan 2002
Genoa Italy
Mercruiser/VM 3.6L 180hp?
It's the 4.2 / 320hp on a bravo 2. It's rated for 3900 rpm with a limiter at 4000, it has no problems getting to 4000 even when a bit dirty so my next step will be to experiment with the propeller.
She weights 3.1 tonnes half loaded so it should go better than this but I'm happy enough with 20 knot cruising. Once I get bored again (in about a month :p) I'll have a play with the setup.
I'm thinking of reducing the prop diameter by 1" and increasing the pitch. She's a 1.65:1 ratio but I don't know the prop specs. All I know is, it's a big diameter which is fairly normal with the Bravo 2
Any advice welcome!
Dino
27 Apr 2009
Ireland
Always loved the Bertram’s. I spent a summer working on Long Island in the US when I was in college and one of the guys in the marina ran a 31 as a dive boat. Got a few spins on it and it was a hoot with 2 x Crusader petrols
Ribtecer
23 Aug 2006
Fascinating post, I'm just about to take out my inboard 150hp diesel for some maintenance to the engine etc and the engine bay.
I'm waiting for some warmer weather, and reading this is very encouraging, I need to know more about engine realignment for its return journey.
I've had big outboards on and off before, inboard yacht engines out, and car engines out, but never a big inboard boat engine.
Space is tight and I am a little bit nervous.
Time Out
19 Dec 2015
great thread, I have my eye on a couple of the Riva 25s so this is of particular interest. One keeps coming down, the other keeps going up !
stelican
25 Nov 2004
fareham hampshire
[/QU[/QUOTE]
Love the detail of that boat , Hope it works out.
jfm
Jersey/Antibes
Very nice job and thanks for posting. Always loved the lines of those Bertrams and Riva Bertrams, and usually see one or two each summer in the Med.
jointventureII
30 Jan 2002
Genoa Italy
Thanks all, the reality is that the white superstructure needs a repaint and the interior is still to sort out, for the most part.
The decision to buy this boat was for a few reasons.
1) Price - it was very cheap. I'm a superyacht skipper during the day so I can do almost all of the work myself, know enough people to get very solid advice where I'm not sure and have a huge range of tools available that'd otherwise cost fortunes. If I'd had to pay someone to do this work, I'd never have bothered. That said, if I ever need to strip a hull in the future then I'll gladly pay someone.
2) Great boat for the family - single diesel so economical, has a cabin that is large enough for the wife & 2 kids (ages 4 / 2), exceptional seaboat. I also wanted to teach my kids, in the same way that I learned with my dad in Jersey when I was a kid.
3) Wanted a project
It's not nearly as daunting as it might seem. Just write down absolutely every step and take pictures. I made a numbered list, then labelled everything on the engine / everything that connected to the engine, with the number. E.g. Starter motor feed would be labelled with a 1, then the threat it attached to with a 1 as well, plus a photo.
The first time took me about 4 hours to disconnect, dismount etc but the 2nd time was less than 2 hours from beginning to engine sat on a pallet. The access is pretty good here, admittedly, but it's nothing to be scared of. Just make sure it is properly aligned when going back.
Time Out
19 Dec 2015
I have seen a Riva Bertram 25 Sport Fisherman with a Kad32 fitted, immaculate refit, sadly it was a spoof ad but the boats out there somewhere!
The two I am looking at obviously have the Crusader V8s in which while great won't help my wallet or be very happy on the Thames which is where I tinker in my free time.
The idea of a single diesel though appeals to me greatly so perhaps I may have to go down the non Riva route.
Looking forward to following this thread and seeing her in the flesh one day.
