Rigger Mortice
N/A
With that type of keel & all the previous I reckon my granny could work out what happened.
Maybe the MAIB will call her as an expert witness?
Am I the only one to observe a spot of rust around the aft keel bolt on the pictures of CR's hull?
It's correctly spelt Taliban, by the way.
There was a whole article in YM about it..
As there has been no diver inside the wreck (only a surface swimmer reached in - they aren't divers) is it possible there may be bodies inside? I can't see how the wreck could be recovered but will divers be sent in to look?
Mandy Rice-Davies "He would say that, wouldn't he?"
It is stupid to disagree with the experts that post in here regarding the poor design and weakness that a bolt on keel gives.
i sincerely hope so
I had a Westerly with a 1/2 tonne fin-and-bulb keel which was help on by two rows of eight 3/4" stainless steel bolts. It surprises me to see how much less steel is used to attach the keels on more modern yachts ... but since keels very, very rarely fall off I presume that Westerly grossly overengineered things and modern designers, probably because they have access to much better stress modelling tools, can specify things far more accurately.
JumbleDuck;47693I said:I had a Westerly with a 1/2 tonne fin-and-bulb keel which was help on by two rows of eight 3/4" stainless steel bolts. It surprises me to see how much less steel is used to attach the keels on more modern yachts ... but since keels very, very rarely fall off I presume that Westerly grossly overengineered things and modern designers, probably because they have access to much better stress modelling tools, can specify things far more accurately.
II owned and loved a Westerly 33 FIN keeled ketch for 14 years and it was heftily built but it had some stupid bits in it's build too...
As Structural Engineer I confirm that IMHO you are right but mistake can happen. Just look at the amount of steel in modern bridges compared to the heavy steelwork and massively bolted/riveted connections in old structures. However failures do occur as Westgate bridge and others demonstrate. Cars have got lighter yet stronger and protect passenger better now.
One question that may arise is what magnitude of force from an impact or grounding should a keel resist.
Another case of the true Satans, the Accountants, being the root cause, then?
They skew the true meaning of "Fit for Purpose" with their obscene Bean Counting. Thank God they aren't allowed anywhere near the RNLI's spec-ing department. Give me honest "over-engineering" ANY time and that goes for building construction too.
THen there were the westerly chain plates on Centaurs that spanned the coachroof windows and on one occasion I saw personally resulted in the chaIN PLATE and half the cabin to being pulled off and dropping the mast over the sideas a result, this happened in a F7 close to inshore rocks and the boat and crew were rescued by Weymouth lifeboat, we were one of two boats that stood by and later escorted the Centaur under engine back to it's home mooring.
