Dinks66
Hi Anders,
I have finally managed to upload some photos of my Inverter set up. The inverter can be seen mounted Stbd side up out of the way under the helm station. I have fitted an isolator and Mega Fuse in line so that it will give better access to change fuses if reqd. The battery tray with the 4x AGM batteries(140 AH) has them on top of each other and makes for quite a tidy installation. I mounted the remote panel just above the 12v power outlet at the helm station but forgot to take a photo. You can see how I have set it up in the Lazarette also. I just have to reach down and select Shore or Inverter on the box on the right. The same RCD Breaker is utilsed downstream of this. I did need to fix a larger marine ply mounting panel for this. All left to do now is earth bond the inverter chassis to the engine and sort out a new 3 outlet MCB under the helm station so that the battery charger supply can be isolated when on inverter power. It will then be ready to connect the 2 x battery leads and off we go (hopefully). I also got rid of the useless space robbing bin from the galley cupboard and made myself a shelf which has increased the available storage no end. I will keep you posted and post more photos once I have fitted my cockpit table and LED's.
