superheat6k
This is what I made - not perfect but it was free and does the intended task perfectly ...
Between 1/8 inch and 2 inches, there are nine separate external diameters in Sched 40, of which 3 sizes share the same nominal wall thickness. I can't imagine for a second that e.g. Solent Clown would assume that one wall thickness is related to one ext dia. That would be grossly unprofessional.
I guess that Brent is applying the great tradition of USA shade tree mechanics to marine metal work...
Who said anything about the USA?
I avoid the place like the plague! I never go there any more.
Radius you can bend depends on the size. For 3/4 or 1 inch sch 40 stainless, I can get it down to a 12 inch radius without the wall collapsing.
Bump and bend it and you can straighten it back out , with no problem, unlike the extruded "yottie" tinfoil walled stuff they use on "yottie" priority boats.
( "Yottieness" logic is where they wear high visibility , bright yellow sea boots, so rescuers can see their feet, when they are chest deep in sea water).
Some 36 footers used 1 inch sch 40 lifelines, some used 3/4. The difference ,sailing, was completely unnoticeable. The difference in strength was huge, as was the ease of welding it up, and the reliability of the welds.
I don't like the fragility of "Yottieness,"never have.
Hans Christian Anderson already cornered the market in fairy tales, even if BS' version is more Grim. Tube bending is a huge part of my day job, and we have tens of thousands of pounds worth of equipment for the job. I would happily of used a tree if it worked for doing proper work.
Stuff and nonsense. No need for him to post it on here, it does not serve the OP at all
But it does serve a useful purpose, that is how not to do it.
I have noticed that he never puts up proper pictures showing the stuff he has made.
Most of the advice given on boats is "just throw money at it, and if you don't have money, give up the dream, and leave cruising to the rich."
I try point out alternatives which the not so rich can use, to keep the dream alive, as well as what can be done in the middle of nowhere, where a cheque book wont work.
The "just throw money at it" suggestion assumes one has the money to throw, and that one is constantly just down the road from the ship chandlers to throw your money at. That is only the case for a tiny portion of this coast, and many others.
Yes,if you have the money, use it but don't suggest that is ones only option, or the panacea, as you constantly do. That lack of imagination or innovativeness is excruciatingly boring.
Suggesting that tig welded tinfoil is as strong and reliable as stick welded sch 40 stainless, is laughable, as is the suggestion that bolted down on plastic fittings are as strong an leak proof as welded down stainless.
i was rowing up Ladysmith Harbour and saw the former Aussie Americas cup challenger "Dame Pattie." The main sheet blocks were two cheeks of aluminium plate with spacers,just like the ones I make .The only difference was lightening holes, which had no effect on basic function . I could make them in a matter of minutes for less that ten dollars worth of material. Putting a huge price tag on them would not in any way,automatically make them better or more functional.
Rotax you just spent a lot of time banging on about your personal opinions .Attacking me is like the pot calling the kettle black. Look in the mirror while doing that. It will bore you to death, if that is the kind of thing which bores you.
Do I wish I had spent my early 20s doing things the way my critics suggest for others, working to buy things I don't need , with money I don't have to impress people I don't like, instead of cruising the South Pacific resourcefully, in ways which they don't "approve" of?
Not a chance.
I am not suggesting my way is the only way. I never have. It has proven one of the best ways for someone who is not rich, and doesn't want to take forever to get out cruising. How quickly I got out cruising is concrete proof of that.
For a block on most cruising boats, the friction between a 3/8th inch SS bolt and a poly sheave is tiny and thus irrelevant, especially with a larger diameter sheave, giving more leverage on the bearing surface.
If one wants to take the time, one can easily make the hole big enough to put 1/4 inch rods between the sheave and the pin, for roller bearings, before putting the sheave in the block. If you did one sheet block this way, and the other without the rollers ,I believe the difference would be unnoticeable.That would be an interesting experiment ,which would prove my point .
Rollers are a sales gimmick.
Now that we are awash in used gear in excellent condition, going one size bigger on the winches would be a better idea, for more power.
Interesting how we consider "Custom made" and "Hand made" marks of quality, while "Home made"is considered derogatory, when they are exactly the same thing!
