Chindit
I own a Bavaria C45 which was built in 2018 and was one of the early boats to come off the production line. Generally very pleased with her performance and build quality but I have been appalled by Bavaria’s resistance to fixing a major safety isssue with the Nav Lights which affects my boat and other C45s.
All of the switching on the boat, including the Nav lights, is operated by a Naviop canbus system. instead of the usual circuit breakers, lights, pumps etc can be switched using the touchscreens on the three plotters (one in saloon and two in cockpitj. This works most of the time but in case the system fails (which happens occasionally) Bavaria supply emergency override switches for the three bilge pumps, saloon lights and supposedly the Navlights. However the Navlight switch is just wired to switch on the Steaming Light.
The net result is if the Naviop system goes down you can only switch on the steaming light. This is a single white light shining forward which is not permitted under the colregs. Other vessels at night will see the single white light and assume it to be a stern light on a vessel sailing away. This could result in a collision and in extremis loss of life.
For the past year Bavaria have persistently refused to correct this so that the emergency override switches on either the the forward and aft Nav lights or the tricolour. Apparently it would involve one and a half days labour due to the way the boat is wired and Bavaria clearly do not want to incur the cost.
As this is a safety issue I do not want to back down and also want to ensure that the issue is corrected by Bavaria on all the C45s with this incorrect Nav light configuration. I am now trying to get the MCA to take action and contact Bavaria.
in the meantime, watch out next time you see a single white at night. It might not be a vessel sailing away ahead but a Bavaria C45 heading directly towards you.
