Bavaria 31
brians
Can anyone advise where Bavaria fit the calorifier and what capacity it is? I am planning to retrofit one.
tony_brighton
Got a 34 but I dont suppose its any diferent - mine is under the aft cabin bunk. Not sure of the capacity - probably 20-30 litres.
marchhare
31 May 2001
Boat Chichester, me Wiltshire
I can confirm it is under the aft cabin bunk, had it fitted from new but there does seem to be ample space to fit. Not sure of the capacity, have had a look at the "paperwork" but not readily identifiable, supplies enough for general use and heats up very quickly.
brians
Thanks for the reply. I assume you are referring to the area on the centreline of the boat immediately behind the engine/saildrive where the exhaust runs. Most of the space beneath the bunk is taken up by water tank, pump etc. I fear the depth of void on the 31 is not as deep as on the 34 and will not accomodate a calorifier. Probably have to locate in cockpit locker.
