TernVI
Before you test a battery 'to see if it's OK' you need to decide what 'OK' is.
For a car battery, the main things you want are enough capactiy to power the alarm and other background loads for say a fortnight, and enough cranking amps to turn the engine.
You can either test that with a starter motor and a volt meter, or a high current tester. A clamp meter to see the current is also good.
By the time car batteries become 'suspect' they are usually a very long way from their new performance, and there isn't much in the way of grey areas, its performance is dropping by the month.
Mostly you need a good charger, so you can prove the problem is the battery not the charging side.
For a boat's house battery, you mostly want to know its capacity and maybe self discharge.
I would test the capacity by taking 10 or 20A and looking at the voltage over an hour or two.
But what are the pass/fail criteria? We've happily got another season out of batteries which have lost 30% capacity and discharge themselves noticeably if you leave them for a month. They're Ok for what we need, but I wouldn't set off on a world cruise with them.....
AIUI, the complex electronic chargers can determine the AH capacity of a battery, and lots of other characteristics by doing a few measurements very quickly at different current levels. That's what you want in a commercial situation, I don't need that. I need to know how long it will run the fridge or nav lights for, and whether that's much worse than last year.
