GHA
GHA is entitled to his beliefs. I'm not expert enough to explain why they are superb or a waste of time.
What i can say is I've read enough Web sites and watched enough videos on various testers and battery related science, how they work and gone more far more technical than I can understand to conclude it's only a small minority that think they are a waste of time .
I've tested hundreds of batteries and mine has been spot on .
These testers will tell you the current state of life by ohms.
Seems unlikey, still more than happy to be wrong, but you need to link to some data for that really.. just saying "mine is spot on" means absolutely nothing without 20H controlled capacity tests to demonstrate the accuracy.
From a *very* quick google...
Electrochemical Impedance Spectroscopy and Determination of the Internal Resistance as a Way to Estimate Lead-Acid Batteries Condition
"Attempts have been made to find the best procedure for the detection of premature battery capacity loss (the so called “PCL”) in AGM-VRLA 48 V batteries operating in telecommunication systems. However, recorded changes in internal resistance and potential did not give clear indications of the beginning of the PCL effect. The obtained correlation between internal resistance and potential derived from used batteries does not show the expected trend in measured parameters. It seems that the application of Electrochemical Impedance Spectroscopy (EIS), which is a faster and non-destructive method, may solve this problem. "
Electrochemical Impedance Spectroscopy (EIS) - PalmSens.
Electrochemical Impedance Spectroscopy (EIS) is an electrochemical techniques to measure the impedance of a system in dependence of the AC potentials frequency.
Electrochemical Impedance Spectroscopy (EIS) is one of the most complex techniques in electrochemical research. On this page the basics of EIS are explained, i.e. the excitation and the signal as well as the recorded values. The visualization and analysis of the EIS data is explained in the following chapters.
For 40 quid?? Seems unlikely... just saying it's good isn't any good - bring on the data!!!!
