Battery Protection
Davydine
11 Jun 2001
Essex
I am looking to buy a cheap electric cool box which will plug in to a cigarette lighter type socket. Only problem is that I am concerned that it will discharge the battery. (not really a problem as I do have a second battery to start the engine but still would prefer not to have one battery totally flat)
Is it possible to buy a device which plugs in to the socket which will switch off the cool box (or any other device for that matter) if the voltage drops below a certain level? I know that I can get a cool box with built in protection but these are a lot more expensive. Tesco's are selling very basic electric cool boxes for £29.99!!
Many thanks
David W
I can provide you with a very simple cct you can build yourself if you are interested. I have already typed it up once and the system crashed so if you are interested you will have to send me your PEM
Roger
Towsure (www.towsure.com) will supply a device called a "MOBITRONIC Low Voltage Protector", which plugs in line between the coolbox and the battery. The description says that it protects your battery by cutting the supply at 11.6 volts. It costs under £8.
... of course, 11.6 volts might be a bit low ... I'm sure someone will know.
