DoubleEnder
I need to buy some standby nav lights. Boat is 34 foot sloop. Any tips, recommendations?
Thank you
Thank you
I’ve got these LED Flex Emergency Navigation Lights Set of 3 Waterproof Boat Sailing J68 5204980726638 | eBay for my boat which is a 40 foot sailing boat. They’re more reliable than the screw down versions and easy to fit to the pulpit and pushpit rails.
Given that they’re emergency lights I’m not too fussed on sharply defined cutoff angles.... The construction of the lights is such that if the fore lights mounted on a vertical pole and the aft light mounted on a horizontal pole, they’ll deliver more or less the right angles for their positions. The other type with the clip fixings and shade are more precise but suffer from two problems: you’ve got to screw the clip fittings in place and secondly the lights themselves are pretty rubbish in terms of reliability (all too often you’ll try to turn them on and they don’t function: the screw down mechanism just doesn’t make reliable contact.)
What about mounting to a small ply sheet and then have clips on back ?I had it in mind to just cable tie the clips rather than screwing them to something if I needed to use them. I'd struggle to find something to screw them to...
I have those too. Very good. Mounted the side lights to strips of timber that cabletie to the shrouds. Sternlight fits to boom gallows.These from Boatlamps (the LED versions) are excellent. Emergency Navigation Battery Powered LED Lights (Set of 3)
I acquired some Plastimo ones with the boat, and as well as the light output being pretty minimal, they have a tendency to run the battery down in storage.
