cmedsailor
I would like your opinion please. I have a NASA BM-1 battery monitor that after 6 years it seems that it’s time to replace as it has stopped working correctly (amp seem not to show correct). What I liked a lot on the BM-1 was the ability to see current amp in (charging) or out (discharging) as well as the cumulative. Amperes in were from the engine or my solar panel. I was zeroing the amp meter after removing the shore power with full batteries and then was easy to monitor what was going on since the BM-1 was doing all the mathematics. The cumulative figure was a good way to see the state of charge of my batteries.
Now I am considering two options. Either replace the BM-1 with a new one or buy a Balmar smartgauge. I understand that the Balmar is a nice piece of equipment that gives the state of your battery quite good but does not show any amperes, only voltage. I could live with this as long as I have an ampere meter somewhere to show me current amperes in or out (I am particularly interested to see that my solar panel is charging and how much).
What do you recommend? If I go with the Balmar smartgauge can you suggest any specific amp meter to use? I can find on ebay many cheap ones but cannot understand if these are OK to use.
