Ian_Edwards
On our last cruise the starter battery failed, it's a sealed, valve regulated, 110 amp hour, wet lead acid battery, in its 6th season.
We first noticed the problem when the gas alarm went off, showing both LPG and CO alarms, we couldn't smell LPG and we were sailing, no engine, no gas cooker or hob lit.
When I lifted the floor boards to have at the LPG sensor, the reason for the alarm became clear, the started battery was very hot, and acid had escaped from the battery vent.
The only source of charging in use was the 200 watts of solar panel, pushing out about 17 to 18 amps with about 13.3 volts at the batteries (hot sunny day in NW Scotland), via a Morning Star MPPT controller.
The wiring for the batteries is very simple, all the charging sources are brought to a common point and connected to the starter battery, a voltage controlled relay will then parallels up the domestic (500 amp hours) and started bank when the voltage gets high enough.
The only thing I can think is that the battery failed with an internal short circuit.
Is this likely?
Is this likely?
