Norman_E
My boat has four batteries, all charged from a single output Mobitronic switch mode charger. The engine start battery, and the two domestic batteries all charge OK, and the engine battery appears properly protected from discharge. The problem is that the bowthruster battery gets very hot indeed when charging, and gasses, requiring frequent topping up. It only charges to about 13 volts measured with a little digital meter, and the domestic batteries give the same reading, indicating that they are in fact all linked in parallel. With the thruster battery disconnected, the other batteries get a better charge.
After disconnecting the bowthruster battery and charging the others for two hours, then turning off the charger and letting the voltage settle I get readings of 13.07 volts from the domestic batteries, 12.67 volts from the engine battery (which is a sealed for life type and has no difficulty cranking the engine).
The bowthruster battery has been disconnected for 24 hours and reads 12.63 volts.
The question is why does the bowthruster battery (which is a Bosch 120 amp hour heavy duty model) get so hot and gas so much that I had to add about 2 litres of water to it before its last charge? It seems to be holding a charge and therefore not dead yet.
