Plevier
See comments below.
What is 'a decent period of rest' and 'a bit of discharge? Would not 'prolonged storage' result in a 'rested' condition?
## I meant open circuit voltage either after prolonged storage, or after a rest period following a partial discharge. In other words, not immediately after supplying a load. I hope that is clearer.
I have read that battery manufacturers cite 24 hours for the fully 'rested' condition, but have also seen a references to 4-6 hours for a reasonable approach to rested condition, so V at 0A is presumably for a period less than that?
## There's no exact answer. You might need as much as 24 hours after very vigorous charging. 4-6 hours would be more typical.
I had also assumed that a very high prior load, relative to battery Ah, could distort subsequent V at 0A, but that (for a 100Ah battery, say) a period at 5A or 10A discharge would not.
## I would agree a 10% load won't have a lot of effect. However you are looking at pretty small voltage variations here so wise to give some recovery time. Probably 30 mins would do.
No, voltage measurements alone cannot reveal a battery which has lost substantial capacity, I accept. For that, see posts 2 and 3. As I say, I just use the table as a rough guide, assuming batteries in good condition.
## Fine, but don't expect great accuracy.
