NigelCraig
Is 13.4V Ok for a 12volt battery? Best I could achieve after about 6 hours on an ordinary cheap auto type trickle charger.
Got there in the end, thank you. Isn't it annoying when the forum software messes up your nicely formatted tableState Of Charge (%) versus Voltage for various battery conditions...
Nigel
Thanks - unreadable so removed it! I'll try again - should be able to get it on the web but can't find the link at present!
On charge ? no to low
Off charge, let it settle for 6 hours, looking for around 12.8 volt, but may have surface charge, not deep charge thus small capacity.
Brian
I'll go away and learn about Photobucket.
I just remember that 12.8v is fully charged and 11.8v is fully discharged.
... my thanks!In the meantime: ...
Sorry to but in BUT...11.8 IS NOT FULLY DISCHARGED. I am not alone on here when I say that a battery down to as low as 10V can be fully recovered. I know this as that is what I have done.
Over to the experts
Peter
In the meantime:
Also, .ZIP file of Excel spreadsheet attached.
can you explain "V, at 0A" does that mean " battery has been discharged a bit but the load removed and battery not rested"? Sorry if I'm being thick I can understand the rest of it.
Some AGM batteries have a fully charged specific gravity of 1.300. This will give you an OCV at 25 degrees of 12.9-13V.
Truck/leisure batteries are usually about 1.260 giving an OCV of about 12.7V.
Some heavy duty industrial batteries are as low as 1.220 giving an OCV of about 12.4-12.5V.
There's quite a range, and of course it is temperature dependent too.
Whether a lead acid battery is fully discharged is a matter of definition. It's a chemical process occurring more and more slowly as the active materials deplete so in theory you will only approach it asymptotically. In practise you do not run it to exhaustion of any of the active materials.
In wet batteries there is a surplus of electrolyte and a surplus of negative plate capacity, but normally the positive plates will be pretty fully converted to lead sulphate by the time the s.g. is down to 1.100 giving an OCV of around 11.7V. It is really not a good idea to go below that! Really deeply discharged plates are harder to recharge.
In AGM and gel batteries there is a near stoichiometric quantity of acid or even a deficit, so if you over-discharge you can get it virtually to 1.000 i.e. water. If you do this the battery is very difficult or impossible to recharge. There is in these batteries a surplus of positive plate capacity, but the negatives will be pretty fully converted by the time the s.g. is down to 1.100.
So for all 12V lead acid batteries, it's wise to consider something like 11.8V as fully discharged, even though that doesn't mean you have converted all the active material and taken the chemical reaction to completion.
Alright Peter?
No it means open circuit voltage after a decent period of rest after a bit of a discharge, or after prolonged storage. (It won't change much after a low load but it matters at high load.)
The open circuit voltage will give a reasonable idea of the state of charge of a healthy battery.
What it will NOT do is tell you whether a battery is healthy and capable of delivering its nominal capacity.
