AlexLbk
Active Member
The current usable is 140*3/2=210, lithium should give me around 600 with 4 206Ah batteries. Correct?The alternator is not charging 6 batteries - just 3. The engine start, thruster batteries do not need charging as they only use a few amps at a time and they get priority so are charged within minutes of startup. The alternator is correctly sized as is the original mains charger. Your "problem" is your high consumption, so extra capacity is the answer if you want to consume at your current rate. space considerations do lead to lithium, but a bank that size (300Ah+ compared with your current usable 150) is a big investment in both batteries and systems to use them properly.
