stevecray
Active Member
I have a 2004 Ribcraft 585 with a simlar age Honda BF90 that started fine 2 months ago but now seems unable to get enough current to the engine to either turn it over or operate the lift motor (faint click but that's it). Initially I assumed it was just a flat battery but replaced that and it made no difference. Have cleaned all the connections from the battery terminals, through the isolator to the engine and also temporarily bypassed the isolator but no difference. Voltage at the engine end of the cables is 12.6v - pretty much the same as at the battery. So to try and rule out a problem at the engine, I hooked up a battery directly to the engine (the normal battery location is in the console, roughly 4m ahead of engine with the power leads routed under the deck to the stern) and it fires up straight away and the lift motor works fine too.
So my only idea is that there is a problem with either the positive or negative cables running through the boat that is not a complete break but enough to prevent enough current being drawn to operate the starter / lift motor.
Before I go down the path of replacing these cables, could anyone more knowledgeable comment on whether my thinking is likely to be correct?
Also, suggestions on cable size / rating for an estimated 5m cable length that has to run from the isolator in the console to the engine and carry enough current for starting the BF90? Unfortunately I did not think to measure this when last with the boat and would like to order cable if that is indeed the problem.
