oldmanofthehills
The consequences of failure of a parallel bank are fairly trivial for an aux supply system, particularly if it is done Westerly standard as 1 - 2 switchable, but even if not it is the work of a few moments to transfer load via jump lead to a dedicated engine start battery.Connecting batteries in parallel – BatteryGuy.com Knowledge Base
That article says more about the problems that can occur if the batteries are not of the same age or type, or you get unlucky and one of the batteries starts to degrade or even fail before the other. One check you can do is to check the voltage of each battery to make sure that they match, that will show if one is starting to degrade. As I said before the risks of connection two batteries of the same type and purchased at the same time are minimal, but even if you connection a battery of the same type to an older one, it's asking for trouble in terms of how the pair perform.
The irritation of aux batteries going flat due to our 21st century usage is ongoing. The annoyance of rebuilding boat to accomadate a bigger single battery or wrecking ones back lifting one in, are both high prices to pay.
There is the ideal blank sheet of paper solution, but as an engineer I would always seek the most practical or lowest footprint one
