skipmac
Lots of good and some not so good information here. If I may summarize some of the good points and information.
1. It isn't volts that start an engine, it's how many amps it can put out. For starting batteries that would be rated in CCA (cold cranking amps). Look at it this way. You could string a whole bunch of AA batteries in series (series voltage adds, parallel voltage stays the same but amp hour capacity adds) so you have a 24 V supply or even more. That isn't going to crank a diesel. But if you have a great big battery like an 8D and a small engine, that battery will crank that engine quite well even at a fairly low state of charge.
2. Voltage is a very rough indication of the state of charge of the battery. BUT, if you are drawing from the battery for a fridge for example, the voltage will read lower. The bigger the load the lower the voltage reading. Turn off the fridge, wait a couple of minutes and the battery voltage will increase. If you have been running the engine and charging the batteries, immediately after you turn off the engine the volts will read high. Wait a couple of hours (with no loads drawing from the battery) to see the true voltage. This is called the resting voltage. A fully charged, liquid filled lead/acid battery will read about 12.6 V at rest.
3. If you are often in a situation where you have no way to charge the batteries except by running the engine then it is, as a friend of mine used to say, the height of folly, not to have a separate charging battery. It is just too easy to run down both batteries and end up dead in the water (speaking from experience having done so more than once). The cheap, manual method is the 1-2-Both-Off switch. Set to both when running the engine to charge all, then switch to one battery to run the boat, leaving a fully charged battery for starting the engine. A more foolproof method is to isolate the starting battery and charge it with an automatic, voltage controlled battery combiner. That way you can't forget to switch from Both to one and run down both batteries (yes I've done that as well).
