banjo bolts
john
13 May 2001
south west
i can't seem to stop a dripping fuel leak from the banjo bolt fitting on my engine. I've replaced the copper washers and don't think I'm overtightening the fitting. Does anybody have any tips?
snowleopard
Oxford
you might anneal the copper to make it a bit softer, heat in a gas flame until it starts to show colours (yellow/blue) then drop it straight into cold water.
you should in theory do this every time you re-fit as the normal work cycle of heating and slow cooling causes hardening.
Avocet
3 Jun 2001
Cumbria
Is it coming from further up the hose and running down on to the banjo? Is the hose secured to the banjo with a loose Jubilee clip?
