Brent Swain
N/A
If you have made some changes to a design, and are not sure where to put your ballast so she will float level, the solution is simple.
Jack her up and put a piece of shaft under the keel at the designed Longitudinal centre of gravity. Move your ballast inside, fore and aft, until she rocks easily on the shaft. That is where your ballast should go.
As most boats tend to squat , and go down by the stern when you load them up, slightly heavier in the bow is a good thing.
Trim ballast?
On a cruising boat, that is your tools, spare anchors , scuba gear, and any other heavy stuff
Trim ballast?
