Ballast
martynl
5 Jan 2004
I have a Shetland 498 fishing/small cruiser. It is 5 metres long. I have a problem with balance. When stationary in the water I find the bow lifts up too far and this has an affect on performance whilst on the plan.
I have tried adjusting the tilt on the outboard, and this hasn't worked. I have put two heavy bags of sand in the front which has solved the problem but I'd rather not use that unless I have to (space being the main problem).
So does anyone have any advice on what I can use as an alternative to sand. Or any other helpful tips.
Thanks in advance
Martyn
Talbot
23 Aug 2003
Brighton, UK
move the fuel tanks further forward. add an anchor and chain, difficult to really get specific without sight of the boat and what you are carrying.
halcyon
20 Apr 2002
Cornwall
We had a Shetland many years ago, and had the same problem, overcome with two bags of sand up front.
When I sold the boat, I found the problem, at some point in time it had come down on a chain or rock, this had punched a hole in the outer hull on the centre 'keel'. As they are foam filled double hull, the inner stopped it sinking, but the foam acted as a sponge, and held gallons of water ballast in the stern.
Check you do not have the same.
Brian
martynl
5 Jan 2004
Thanks for the replies.
Brian
ok i'll check that. What model of Shetland did you have?
Do you know if there is any way to fix the problem?
Cheers
