Badly marked interior teak. Should I..?
Cobra750
23 Nov 2003
Hi, I have managed to stain my teak chart table with white spirit (inadvertantly put a cloth sodden with the stuff on it & left it there for a week!). Any recommendations on what to do (i.e. restoring teak) is welcome as I'm not keen on buying lots of tins & pots of the wrong stuff & am mot sure if I should sand & varnish, sand & use oil, not sand but use linseed oil & wax, etc etc. Thanks!
Mirelle
N/A
30 Nov 2002
How was it finished to begin with?
Generally. white spirit will quietly evaporate over time; I fancy all you have to do is wait!
<hr width=100% size=1>Que scais-je?
Aeolus_IV
24 Apr 2002
East Sussex
As Mirelle asked, what surface should it have? What ever you do, do not start sanding it - once you've taken the wood away you cannot put it back. If it is varnished I'd suggest that using varnish remover on the whole panel and re-varnishing would give best results. I've done this to our saloon table and it now makes the rest of the boat look tired (/forums/images/icons/crazy.gif). If it is only oiled then time will probably cure it, though again I have found that paintstipper helps clean old dirt and oil out of the wood before re-oiling (mind you this was to floor boards rather than a chart table).
Just my tupennyworth,
Jeff.
<hr width=100% size=1><A target="_blank" HREF=http://users.swing.be/FDB/centurion/index2.html>Centurion 32 Web site</A>
