jrudge
Presumably a Vodia tool on the boat whilst in motion would give more of a clue of what was going on. The Throttle head is simply a potentiometer. You have swapped over the throttles to no effect, but these wires will run back to the ECU somewhere. I wonder if there is a connector that has got corrosion etc on it. This would reduct the voltage to the ECU and demand less power.
If you have a multimeter you could connect this to the wires from the throttle. There will be a reference voltage (5v on a cat, not sure re volvo) that should be the same on both across the outer lugs of the potentiometer, and the voltage from the middle wiper of the potentiometer should increase and decrease in line with throttle movement. Both throttle voltages should be the same give or take for a given position. If they are you could possibly then chase that same voltage level through to the input of the ECU to see if it is the same.
If RKs machine was saying only 94% demanded then I would guess ( and it is a guess) that at the ECU the voltage will not be the same as at the throttle head.
