shetland
Hi JTB,
What plans have you got for the drives?
I use Virosol (industrial not marine) - fantastic stuff either on the boat or at home.We used EVM (EnVirosol Marine) which is a multi purpose cleaner that friends of ours used to market, it is truly superb and we use it for everything on the boat. If you Google EVM marine cleaner you will find it is still available....Jones at St Ives in Cambs are still advertising it.
Hi JTB,
Available here on eBay from Mustang Cleaning Supplies
http://www.ebay.co.uk/itm/Virosol-10L-Twin-5L-Pack-/221345740102?ssPageName=ADME:L:OC:GB:3160
£19 for 10L delivered seems good value to me.
What about a hull wrap, something a bit wild like the colour of the cherry picker?
Point of order, I think it's a telescopic forklift not a cherry picker. You townies, eh....
If you want to be really pedantic about it, it's a telescopic handler.
I assume you have a boat about 2006?
You probably have steering rams to examine and coolers to dismantle clean and inspect?
While the engine is out, the sumps are galvanised I believe, might be worth replacing if in poor condition?
You will probably find your exhaust risers are a bit scabby, the water injection elbows if original will be getting quite scabby as will the exhaust horns, while the engines are out it be worthwhile replacing these.
Did you mean telehandler?![]()
That's a widely used abbreviation, but I think you'll find I'm technically correct![]()
No need to drill down into specific product info, they make it clear on the first line of their home page http://www.merlo.co.uk/
"Since 1964, Merlo has been leading the way in technological innovation across its range of telescopic handlers, ...."
2005. I'm already on my third set of steering rams. Sumps are in good condition. Risers are good. Horns look good to me but in truth I don't know how to tell if they are ok or not. By water injection elbow, do you mean the component at the bottom of the hose #8 in this diagram?
Plan is to have a walk-round review of the engines with RK Marine later this week, and work out a plan from there.
The water injection elbow is the bend after the turbo where the exhaust points down and the cooling water from the engine is injected to cool the exhaust, this is normally a cast iron outer casing with a stainless steel water deflector shield inside, the cast iron corrodes scabs up and restricts the cooling water flow, in my photo you can see my old injection bend and the new I fitted, you can also see the old riser that failed in the background.
My point is while the engine is out its easy to do work to future proof your boat for modest cost. To take an engine out later is a pig.
The exhaust horn no 1 in your diagram do often fail after 10 years or so, if this is below the waterline it could sink the boat, its an engine out job to change it in the future so expensive, if it was mine I would renew it.
