stravaigin
Hi - the MCA code for category D sailing vessels requires that the range of positive stability extend to 123 degrees.
We would be interested to learn from Blue Water cruising folk what is considered an actual / acceptable AVS given that liveaboards tend to have a heavier displacement than the original designer's criteria [which can reduce the range]
Would much appreciate "actual" rather than theoretical findings! Thanks! M&M
