Autopilot trying to kill me?
Do the Vendee boats use the same autopilots as we do?
No, massively more sophisticated, with many more sensors and AI developed capabilities.
BUT the learnings from the race systems gradually feed down into the bread and butter systems. Hence why modern cruising yacht autopilots are much more effective than ones from 10-20 years ago.
I have in-mast main sail, so I would have to turn up wind in 32 knots of wind to reef or pull in the mainsail, so that is out of the question. Easier to just sail close to downwind and roll up the Genoa then
I'm a little concerned about that. I understand the sentiment, but the problem is you are already painted into a corner and if the wind speed rises further . . . you get the picture.
'Too windy to reef' is a sure sign that things are getting out of hand. 'Reefed as a precaution, but it turned out not to be necessary' may make a skipper sound like a wimp, but that's the sort of wimp I want to be.
64 posts in, I too am of the opinion that the boat in question was overpressed. Once the rudder stalls out, no AP in the world will bring the boat back on course, especially when the AP has gone to full lock.
However, some boats are clearly much better downwind than others. We can (and have) carry full sail, see avatar, in 30 kts, on a deep reach and in a pronounced, quartering and occasionally breaking, following sea. This under autopilot, though it never has to correct more than 2.5 degr. rudder angle and at speeds between 7kt and 8kts. The boat tracks like a train.
We could do this with our old AP, a slow and slow witted CPT and now again, with our upgraded Raymarine 150, which is a lot more sophisticated. We have yet to encounter conditions in which the AP could not cope.
I always try to carry as much sail as possible - speed improves ship movement, cuts down considerably on rolling and makes passages more pleasant, especially downhill.
Last year we circumnavigated the UK anticlockwise from our home port in Brittany, via DK, Sweden, Norway and Shetland in less than elegant conditions. We made 5 overnight passages between 200 and 450 NM, always under AP and all without issue.
A long keel in itself is not a cure, in case you were thinking. I've done several ocean passages on a couple; they rolled like pigs downwind and required considerable effort at the helm to keep on course.
An AP that can't keep course in all conditions is not really useful, as when the proverbial hits the fan, it may be the time when you need it most. If the AP can't be relied upon or will not safely steer the boat, then there is something wrong with either the AP or the boat.
While APs have improved a lot over the last years, a common problem is that occasionally ones are installed that are essentially too small or unsuitable for a particular vessel.
Hand steering across an ocean or just across the North Sea, for that matter, might dampen such nostalgia a wee bit. Ask someone who's done it.
It's how I started (not oceans) and I was being ironic - I sometimes think the fun and spirit of sailing can get lost behind all the technology which is now considered normal. And the time spent working on the sailing bits is replaced by wiring, software and manuals.
I am guilty too - I depend on my autopilot, have a furling main and use electric charts etc.
