NealB
Just over three few weeks ago, I removed the very ancient, and very defective, plug and socket from my ancient, but hopefully, not too seriously defective, Autohelm 4000 wheelpilot.
I’ve bought a shiny new, Bulgin Buccaneer matching set as replacements, as recommended by some on here.
Now, this is rather deeply embarrassing to admit, so please keep it to yourselves, but in the intervening period, I’ve been rather distracted by non-boaty things, and I have forgotten which wire connects to which (there .... I've said it
Can anyone help, please?
There’re four wires that come from the black control box to the plug: a thin red, a thin black, and then a thicker brown and a thicker blue.
There are then two black outer-casings, screwed to the underdeck, in the cockpit locker, which lead to the socket. One of the black outer casings is slightly thicker than the other. Each of these black outer casings, contains a blue and a brown wire.
The blue and brown wires, in the thicker outer casing, are connected to the switch panel, so there’s 12 volts across that pair, when the panel switch is on.
The blue and brown wires, in the thinner outer casing, show no voltage.
So ……. when wiring up the new Bulgin connectors, should the brown and blue wires, with 12V across them, connect to the thin red and black wires, that go to the control box? Or, should those brown and blue 12V wires connect to the brown and blue wires that go the control box?
OK …… come on … behave ……… stop laughing .... this is serious!!
Thanks for your thoughts.
