oldgit
Its a lot easier and cheaper to replace a float switch than to replace a integrated pump and switch.
First get those ancient jubilee clips undone if you can get you and a screwdriver in there and at the correct angle,then remove that rock hard old water piping from the now old defunct pump body. .
Hope against all common sense that the new pump bracket securing bracket holes line up with your existing holes.
Hope your new pump water outlet in "mm" is the same as your "imperial" hose diameter.
Boil the kettle and hope to force the old pipe on or worse be able to tighten the jubilee clip sufficently to get it to stay on the pump without leaking.
Resort to cutting of a few inches of pipe to find a bit still flexible enough to seal on pump outlet.
Try to reroute the pipe after finding removal of couple of inches of hose now makes it impossible to attach hose to pump.
Make up some sort of Heath Robinson extention to hose using whats lying around in your lockers.
Or is that just me ?
