steve yates
I used an ordinary shackle, is that ok? Or should I have some kind of spinning/turning connector instead?
Ordinary shackle, moused with monel wire works for me.
BUT, don't use a s/s shackle on galvanised chain (or vice versa).
Don't ask me how I know that !!
Without a swivel I have occasionally had the problem of the chain twisting so much that when retrieved it bunches up or becomes hockled and will not pass through the gypsy.I'm still wondering why people use swivels at all.
One day someone will have a sensible reason?
There was a recent thread about this.
see Vyv Cox's website for results of destructive testing on various anchor connectors, swivels and shackles.
d.
Galvanised, rated, bow shackle works for us.
Jonathan
Perhaps someone who uses a swivel will try to explain how it helps an anchor to come up onto the bow roller, facing the correct way. When my anchor comes up to the surface, it may be facing in any direction, but it's only an anchor, and has no decision-making brain cells. I just don't see how including a swivel helps.
I use a bent link between the anchor and the chain, and it ensures that as soon as the link reaches the roller, the bend in the link, makes it rotate, so that the anchor can only come up the right way. The bent link is a short length of round bar, with a bend in it, and having an eye at each end, then galvanised. Other similar designs exist.
I would not introduce a stainless link or shackle between a galvanised anchor and galvanised chain. I have had a serious loss of galvanising from my chain doing this (admittedly after leaving my boat anchored for four weeks).
I'll give one example. Our anchor is under the trampoline and is not easy to reach. It usually comes up the wrong way and sometimes did that without the swivel. Without the swivel it was a bugger to try and get it round but with the swivel it's often sufficient just to lower it back down to the sea and the forward motion of the boat will flip it. If it doesn't then it is just possible to reach a few fingers past the trampoline and flip it. Because of the swivel it does flip round with just a gentle touch.
I have thought about trying one of the Osculati cranked links (I assume not the Osculati cranked swivel which Vyv refers to) and perhaps I should have gone down that route but as I now have the Kong swivel I'm happy to stick with it until such time as I need to replace it.
Richard
Remember to use a tested, marked shackle.
This is the result of using a plain vanilla one off the chandlers shelf:View attachment 56538
I suspect that thousands of us use a s/s swivel on galvanised chain and anchor and it works fine.
Why would this be any different to a s/s shackle?
Richard
P.S. In response to the post above, I've never had a problem with SS connectors on galvanised chain used for anchoring (and I anchor a lot); yes, there's the possibiity of galvanic action on the chain, but in practice the effect is very, very slow. Keep and eye on it, and be prepared to chop of a couple of links if needs be. But it really isn't an issue. On moorings, underwater 24/7, it's different. (Incidentally there was a recent thread in which this very issue was debated exhaustively.)
Hi, I've seen your photo of that before, and find it most intriguing. How did it manage to break in two places at the same time? Correct me if I'm wrong, but have you not also posted a picture of the shackle, complete with the broken section? If so, it must have broken on deck. Again, if so, how did it break? Just interested.
Dug around all the pics that I took this year, here's another. The third piece I found in the scuppers a few days later.
I was up in Loch Nedd (a bit south of Cape Wrath) winching up the anchor at 5am (there was more than a bit of breeze forecast for the next few days and I wanted to get nearer some 'civilisation' before it came in after lunch). Winching up the anchor on the windlass, came over the bow, all looked normal, then BANG. Anchor fell off into 13m of cold Scottish loch.
Brand new shackle this year. Anchor was a 20kg Rocna and only 3 years old + Kong swivel. Left it on the bottom (how could I retrieve it?). Can't see any obvious sign of failure in the fracture surfaces, such as rusting in a crack forming.
