stephenh
Pugwash60 - I have PM'ed you.
This is more of a moan than anything , but I've always used a simple scientific calculator and punched in the numbers for the spherical cosine formula for doing the basic sight and then used abc tables for the azimuth. My moan relates to modern calculators which I find to be a complete pain in the @@@. The old ones essentially allowed you to use whatever number was in the display and if you wanted the cos or sin of it you just pressed cos or sin or whatever, now you have to put it into a memory then press cos or sin and then bring it out of memory which is so ridiculous it makes you want to cry. I was so cross I ended up buying an HP at huge expense which uses reverse osmosis or something as a operating logik and it would be brilliant except that it doesn't manage to do degrees minutes and decimals of a minute. You can get around it by doing degrees and so many hundreds divided by 600 thereby fooling it but I'm amazed that it can't manage degrees and minutes when even the cheapest of chinese calculators can do that. There is a perverse pleasure in having the HP which people not in the know are unable to make work. Am I the only one who hates these modern calculators. I wish I still had my old Casio fx which was beautifully predictable.
Moan over.
Once you get used to it the HP with rpn is approximately a million times easier to use for longish calculations than the normal style ones from the 80's and more like a billion times easier than the ones made today I can't believe that teachers and lecturers aren't gettting their students to get hold of the older calculators which would in turn get the Casios of this world back to making more sensible to use calculators instead of the ones they now produce which try to get you to put things in in the order that they would be written, and produce a stupid message if you put in x first by mistake and then / later without first having erased the x. On the old ones it pretty much didn't matter which arithmetic function buttons you pushed as long as the last one you pushed was the one that you meant.
