arvor 25 rope cutters
chrisarvor
20 Nov 2003
essex
has anybody had rope cutters fitted on a an Arvor 25. i ask because i did not think there aws room in front of the prop?
thanks
Robin
30 May 2001
high and dry on north island
I don't know your boat but most cutter suppliers will offer spacers of various sizes to fit between the gearbox and coupling to move the shaft/prop back and make room for the cutter. In some instances like with a bearing holder screwed onto the shaft tube exiting from a skeg or a P bracket it might be possible to cut a little from this to make space.
discoduck
23 Feb 2004
Hi
Ropecutters will sort you out ,advert in Boat owners. Don't go for the cheaper ones you are paying for the steel
