Gludy
Recently, I have been studying the use of water jet propulsion V traditional props.
At present, water jets seems to be winning in every aspect:-
No need to worry about nets, rocks - prop damage etc.
Constant load on the engine, not a varying load as the prop is moved up and down in the wave.
No gearbox - less to go wrong
Safer when anyone is in the water - they get, at worst a high powered shower, not chopped up.
A lot less noise, no prop shafts vibrating through the boat.
Engines last longer.
No change in performance with time due to dirty props.
Fantastic ability to move in any direction at any speed and the ability to just move sideways into a very tight berth.
Ability to, in effect heave to in a storm, with forward and backward propulsion balanced as required.
Ability to hold station in cross current and cross wind etc.
Props appendage drag accounts for about 17% of the total drag on the boat - its zero with jets.
Even a 60 foot motor cruiser can dry out with jets - extending the number of places you can visit and also allowing you to get to the hull without a lift out.
I could go on - but so far I cannot find a single advantage of props over the jet propulsion. So as a beginner to all this, I started to ask myself - why none of the big production companies use them. I find that Sunseeker tried them about ten years ago but also find it was not a real try - they did not change their hulls to suit the jet propulsion, they had problems with the control system.
I also find the RBLI are now experimenting with jets and the MOD has ordered a pile of jet boats after carrying out tests that involved putting a 30 footer onto a trailer in a 7 knot current by simply going sideways onto the trailer.
The RNLI spent days going through a pile of intentionally placed rubbish to get some into the water intake and after a number of days succeeded in sucking in a rope - they simply lifted the hatch cover and took it out. No need for a lift out, no need for a mechanic.
Many commercial ferries use jets because of the savings they make on engine maintainance plus the amazing ability in their ability to manouvre.
So are the big production companies wrong? Is the market too conservative - is their a huge resistance to change? Or am I just a beginner who is missing something? Tell me.
Paul
Paul
