Portofino
How’s a about this ?
No “ cord struck “ or similar or whatever .I've obviously struck a chord as intended. Perhaps you'll be a bit more circumspect in your own opinions about fellow forum members boats in future?
I can't understand exactly from the video, what's the trick that you use to keep the fenders in that position?Flatass cutting through chop. Loads of bouncing as you can see
I don't see one in yours either, actually. If you just download one of the many apps available FoC, you can monitor your AoA in real time (as well as the reaction to trim tabs), down to a tenth of degree accuracy.Wheres the “ meter “ in your vids btw ?
I guess you don't untie/re-tie them every time, or do you?
Just a nice simple easy AoA test , the water level .Wheres the “ meter “ in your vids btw ? You know getting round the camera angle etc - might be biased ?
Clue is in the thread title.
Not that I'm so maniac to do such check regularly, but I did and got some interesting results upon seatrial of my boat, and now I keep that in mind for fine tuning while cruising.
Reminding of what ?![]()
I've shown you plenty already but if you need reminding:
Don,t know why your vid has any relevance to a simple bowl of the dogs water, glorified spirit level ?
Get yourself a copy of Linsays Lords book ..........
The basic principles of hull design , AoA , CoG , CoL , deadrise are found in many boats , a lot of builders try and stay close .
Having said that those that drift need calling out .
This is mostly why you need to reduce speed below your superchargers rpm when the sea picks up .
Have a look at a SU35 cobra manoeuvre. Super high AoA (alpha) off a very aerodynamic wing surface, but the induced drag is huge. Thrust beats drag. When not pulling a high alpha manoeuvre it is a very slippery platform and has very little drag.
So attitude is not alpha and the two are linked but not the same.
