Took down furling genny yesterday ... for some reason it was hard to get the foil to rotate ...
Once down it was clear what had happened :
The top castellated nut had unscrewed from the main halyard swivel fitting. I was lucky it all came down !!
Looking at it ... I could see a hole in the "nut" that co-incided with a hole in the threaded centre part when fully tightened ...
But once tightened the hole was half blocked of by the swivel part it held in place ... and if any screw / locking pin inserted would prevent that rotating. So I assume it's a lubricating hole ? There is certainly no mention of this in manual and nothing about it being able to be unscrewed etc.
The only error I can see is that the "cranked" shackle that should be attached to the swivle part is changed by previous owner to a straight shorter shackle .... meaning that halyard hard eye is touching the "nut" ... maybe when hardened up - the halyard is enough to trap in one castelation and unscrew the "nut" ?. I do not have a halyard diverter fitted - the "doughnut" as I have a second line that prevents halyard wrap more effectively ....
So question .. has anyone else had this problem ? Does anyone know where I can get hold of the "cranked shackle" ? to get halyard away from this nut ??
