Murv
Cut slightly oversize then block plane to required. Tip for block plane is to use well sharpened blade and plane slightly at an angle so its slicing rather than chopping.
Thanks for that, I have ordered the router now though, so will have a go with that first. There's one part of the panel that has a small tab, I wouldn't get the plane near that although it would probably cope with the rest of it and I could do that with the Dremmel if the router doesn't work.
As others have said - cut from the back but you need to be able to use a jig saw upside down? or marked from the back, but then you can't see where your cutting! or if you have a bosch jig saw these may be useful as they limit the splintering when cutting from the face - or downward cutting blades.
http://www.ebay.co.uk/itm/like/3103...f11=ICEP3.0.0&ff12=67&ff13=80&ff14=101&ff19=0
I wouldn't actually need to cut upside down, I can just flip the panel over and cut it in negative, that's the cunning plan anyway if I end up using the jigsaw!
It's sadly not a Bosch though, I'm hoping the router will do all of it and make it considerably easier to cut out all the holes in the other panels for switches etc
