Any news from Watchet?
graham
16 May 2001
If it was a one off event there wouldn't be a problem but
Watchet would need an annual major dredge plus maintainance
through out the year to keep even most of the marina clear.
bitbaltic
21 Nov 2011
Boat in Milford Haven
sailingkarisma.wordpress.com
It needs digging out and then a system to keep the entire water column (surface to marina bed) agitated when the sill is up. The settling velocity of the mud is very low, so as long as the water is kept moving (however slightly) it will not silt up again. I wonder if those air bubbler thingies they have in Penarth/the bay would do it. Still there is a cost to running those twice every day for ever.
graham
16 May 2001
The water in Barry Harbour is constantly moving from tide and wind and wave effect .South or South Easterly winds can produce large breaking seas coming into the harbour .
It still requires a major dredge from a ship sized dredger (UKD Orca)annually to maintain the depth .
Allan
17 Mar 2004
Lymington
In another thread on here I detailed a plan to do exactly what Bitbaltic says, using the water from the stream. Relatively cheap, sustainable and practical.
Allan
Birdseye
9 Mar 2003
s e wales
Not sure about that. One of our universities or renamed tec colleges, did a project on the harbour mud and founf that every tide was bringing in around 30 tonnes. Sure it doesnt settle completely but it doesnt need to do so. Even before the marina was built, Watched silted up. The now diverted stream made a cut through the silt but didnt get rid of it so my bilge keeler would leave two furrows in the harbour "floor" if I came in after mid tide.
The marina design was simply wrong.
sarabande
6 May 2005
At 1.3 tonnes of silt per metrecube, that is 23 metrecube per day, or around 8400 m3 each year. Or very approximately raising the entire sea bed by 1.6m each year.
You don't have the citation to the research handy, do you ?
SaltIre
13 Mar 2017
None of your nosey business
PlumDuff's post was per tide - not per day. So should your 1.6m be doubled to 3.2m? Increasing the seabed by over 10 feet per annum does seem problematic.:eek:
Birdseye
9 Mar 2003
s e wales
No. The research was quoted to me by the marina manager at Watchet and it much have been 10 years ago. But its likely if you think about it. Sea comes in carrying the silt as we see all the time in the Severn. Over the six hours that the sea level is higher than the cill, the silt starts to settle down and the water that flows out over the cill has less silt in it than it had when it flowed in. The outflow isnt of a speed that would stir up silt from the bottom and the marina has no ability to flush the basin in the way that happened before the cill was built. I would have thought it inevitable that mud would build up almost to cill down level.
Sure it could be dredged out though I believe they have environmental restrictions on what they can do. But dredging is expensive and marina income isnt that great.
The marina is a dead duck really. No way can marina income pay both for dredging and the maintenance of such large exposed harbour walls.
Snoopy463
28 Sep 2005
Bristol Channel - The sunny side
The low impact dredging does seem to be having some effect, albeit slowly. Are they raising the cill as per usual? If so, depending upon the rate of sedimentation, x tons will be added each tide. If the cill were to be discarded, at least the ebb would take out most of what was brought in by the flood tide. Watchet would then become a mud berth marina, like many on the east coast. No problem in sitting in soft mud to your waterline. Keep the minimal dredging to keep 6 feet of mud above bedrock and even fin keelers will be happy. Simples!
bitbaltic
21 Nov 2011
There will always be more silt in the water column than will settle each time the cill is shut (that’s why the water stays brown). Therefore the only thing that matters is the velocit(ies) of water at the marina bed versus the settling velocit(ies) of the particle size distribution of the mud and silt in the water column. That will govern the rate of sedimentation and nothing else.
as others have pointed out the figures you were given by the marina are not realistic.
NotBirdseye
13 Apr 2019
Wales
I don't think the numbers matter that much at the moment. We know that Watchet is more affected than most other harbours and therefore it is tougher to keep the mud out. So I think we can cut Plum some slack. :) Someone probably put a decimal point in the wrong place! (or didn't convert properly from imperial to metric...).
SaltIre
13 Mar 2017
I've added this thread to my watch list and will watchet with interest.:)
@SaltIre the cloak room is that way...
