Simes
Hi Folks, Whilst I do not get here very often I have been very impressed with the quality of the replys.
The rebuild of Talisman is going OK if a little behind schedule.
The engine has been rebuild and fitted (sans exhaust system), the new battery box is built and the engine box has been designed. The new floors are down, the Galley cupboards draws and worktops will be in by the end of this week.
However, the stove has to go in soon, at the So'ton BS we ordered a Dickinson Adriatic stove. This does seem to be the ideal stove for a liveaboard vessel. The general plan is to fit a 25 ltr "day" tank and to supply this with either a power or hand pump to resupply from main tank. We hope to run 4 1/2 meter radiators and a 50 gallon calorifier from this as well.
Does anyone run these stoves or maybe a similar system. And help advise (good or bad) will be very welcome.
We are also just starting to design the 12 volt system, the plumbing system and the deck layout.
Every job seems to produce at least three new jobs, we hope to be living on board by August!
Many thanks for your help,
Simes
Simes
