SiteSurfer
I’m currently away and have found an issue with my sea water cooling system which only manifests itself after sailing.
here’s what happens, we motor for a while (everything working 100%) and then put up the sails,turn off the engine and then when starting the engine again the water fails to continue to circulate through and out of the exhaust.
I have to manually fill the strainer and prime it - upon which-it all works again perfectly.
this however never happens if we stop the engine after motoring and start it again. Only after sailing.
I hve recently changed the impeller and lip seal on the water pump just in case (the problem was there before) and am confident that this is air tight as no leaks.
given that the water appears to drain back down the pipe into the sail drive and not through the water pump I am suspecting it’s the Volvo (16 year old) strainer.
would that be a reasonable assumption? Or perhaps the anti siphon valve.
just can’t understand why sailing makes a difference!
