Antifouling
tony_brighton
Had the boat lifted out last weekend - off to the yard this weekend to do some antifouling. We're going to try rollering for a change (always brushed before but this boat is bigger) - has anyone got any tips for best usage?
ccscott49
7 Sep 2001
Didn't think anybody didn't use rollers! Use cheapish ones and throw them away after the job, nothing more to say really, scrape any loose stuff off, when wet preferably, (less dust), use a mask when doing so. Just get it lashed on, with an extra coat on the waterline and bows. A little thin skim on the echosounder log is ok.
Viking
23 Jan 2002
Ålesund, Norway.
I use a wide masking tape. I also use a thin radiator roller for a better finish and helps with the 'curves' with a long handle you dont have to bend so far. I use a drop of thinners to give a easy first coating. Use full strength on all leading edges (bow and keel) and on the waterline and rudder.
david_bagshaw
5 Jun 2001
uk
to add to that,
keep roller in a plastic bag between coats.
buy one that takes a broom handle for even less labour
dont dilute unless told too
allow empty tins to dry, but then I have been using the stuff in the netherlands where they are VERRY GREEN
Buy best quality masking tape.
good luck
ps to ccs where were you during the recent N Sea storms ?
David
<A target="_blank" HREF=http://www.euroboating.net>http://www.euroboating.net</A>
ccscott49
7 Sep 2001
Offshore Norway David, it was really fun up here! Even the platforms were swaying about, not very nice!
pvb
UK East Coast
Controversial view!...
This may be controversial, but I reckon roller application for antifouling is not the best way. Antifouling relies on a good film thickness to keep it effective, and you simply don't get that with rollering, unless you apply lots of coats (in which case it's quicker and easier to brush-apply it in the first place). I always apply antifouling by brush, giving at least 2 generous coats, plus a third coat around the waterline and on the leading edge of the keel. This lasts for 2 years, so the effort is worthwhile.
FlyingSpud
4 Aug 2002
Kent, Medway
Re: Controversial view!...
I have found pads are better than rollers, just as quick as rollers but give a better coverage, and don’t spray as much. They fall apart after about 20 minutes use, but as they only cost pennies, what the hell
ccscott49
7 Sep 2001
i think you'll find it depends on what type of roller you use, a real hairy one will give a better layer, I also put two coats on, with three on the waterline/bow area, but most people slip there boats every year, In fact I buy 40 litres of antifoul and put it all on, I find this lasts about 2 1/2 years in the meddy. I slip mine when it needs it. I dive under to check and clean any bits that need it.
Gunfleet
1 Jan 2002
Orwell
Colin... 40 litres of antifoul! The thought makes my wallet shudder. I hope they give you a discount.
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Make sure the rollers you buy will resist the strong solvents in antifouling. Many cheap DIY ones, especially foam, last no more than a few seconds. The ones sold in DIY outlets for solvent-based paint are often not much better.
ccscott49
7 Sep 2001
I buy it in 20 lityre drums, very cheap, if you klnow where to get it, nudge nudge /forums/images/icons/wink.gif /forums/images/icons/wink.gif
