duncan99210
Given that it’s a 40 year old boat, I wouldn’t bother with doing anything to the hull once stripped other than applying a primer comparable with whatever antifoul you choose and then putting 2 coats of antifoul on. I see no need to sand the hull, it’ll be pretty smooth after blasting anyway and if there’s any paint left the blasting person hasn’t done the job properly. The primer will fill any minor imperfections.HI. I'm considering getting my boatyard to blast the antifouling off my 35 footer. GRP hull, 40 year old boat. Once it's off what do you reckon? I've been advised by a local chanldery to gor this approach considering the age of the boat:
Sanding, 2 coats of epoxy primer, 1 coat hard antifouling then a softer antifoul which will be jet washed and repainted annually.
Anyhow, that’s what I did when I removed the antifoul off my 51 year old boat. It worked fine with no adhesion problems with the primer or antifoul. I used the cheapest antifoul and primer combo in the local chandlers and it works.
