snowleopard
been having trouble with the water pumps on my yanmar 3gm30s. the water from the saildrive leg goes through a vetus strainer (above waterline) and the pump often refuses to suck water until i disconnect a hose and suck it through myself (yuk).
at first i thought the cover plate had worn and allowed air past, then i see in the manual there should be 0.2mm clearance between impeller and cover plate. when the pump is full of water the gap is too small for water to leak through but it seems as though air in the pipes can escape past the impeller so it doesn't develop enough suction to lift the water over the strainer. the problem seems much worse since moving to a drying mooring which lets water drain out of the pipe.
i guess leading the inlet water direct to the pump without leading it above waterline would cure the problem but i don't want to lose my expensive strainers.
has anyone hit this problem and if so, what is the solution?
