Another solar panel question. Sorry
Highndry
7 Apr 2011
Nr Uppingham, Rutland
I have a heavy duty deck plug that I connect an electric outboard to. Between it and the battery there's a 50a breaker. Could I simply plug a 10W solar panel into that deck plug and expect it to work?
Yes.
If I were doing it though I would want to think about a fuse, particularly if I was leaving the boat unattended with the panel connected up. An in line 1amp fuse might do the trick, but I'm not sure, as it would be exposed to the elements, if suitable genuinely waterproof ones are available.
Would def charge the battery.
The fuse is there to protect the wire, so unless it's a very large solar panel, the fuse is likely to be a tad over rated.
The panel & wire might go wrong and then you'll have 50A going through it until it fries.
Depends if you think that is likely / going to bother you.
Yes OP can use the power outlet to feed in solar charge. The wiring to the outlet will presumably be rated to suit the 50 amp circuit breaker.
The wiring from the panel to the power outlet will presumably be quite light.
Question becomes is it likely to short one wire to the other?
Is the wiring likely to cause real damage or fire if it gets red hot and melts.
If the answer to both these questions is no then you might risk no fuse. Certainly a fuse will be a further fault source. olewill
