bc22
Hi All
I hope you are enjoying this bank holiday weekend.
I am having some recurring overheating issues with my Sealine S23 fitted with a KAD32 engine and I am starting to suspect that it could be a faulty sensor or alarm.
An overheat alarm goes off above 90degrees C, but the boat rarely gets any hotter than about 91/92 even at max chat.
I have done a full service on the boat including a flush of both the Seawater and Freshwater sides, new impeller and new belts. Flow through the cooling system seems ok and the Flush brought the overall temperature of the system down by a few degrees.
The boat behaves beautifully until trying to get her up on the plain.
A few questions if I may to help me with my further troubleshooting.......We all know how hard it is to come across what you need in both the Volvo and Sealine manuals!
1) Is there a separate system for both the dashboard temperature gauge and the warning alarm?
2) What temperature SHOULD the alarm go off at? I can't find in the manual, but have read elsewhere a number of 97degrees? If so, this would suggest the alarm is at fault as the gauge doesn't go above this.
3) I assume the temperature gauge is indicating Oil temperature? If so where is the sensor on the engine, as i can't find any reference to this in the manuals? Is this worth a change or a clean up?
Any suggestions would be more than helpful.
Thanks all
Ben
Thanks all
Ben
