richardbrennan
I am a bit reluctant to dip my toe in the water with another battery question at the moment, but would appreciate some advice.
It's clearly time to replace my Lifeline AGM batteries which are now more than ten years old. T-105s are not an option as they would require major surgery to the battery boxes, so I am looking at quality AGM batteries that are the same dimensions as the Lifelines.
I currently have two Lifeline 31Ts in the domestic bank and one 3100T as an engine start battery, the charging is handled by a voltage sensitive relay. The obvious replacements for the 31Ts would appear to be either the Trojan 31-AGM or the Rolls S12-128AGM. There would appear to be no obvious equivalent to the 3100T which has a CCA rating at 32 degrees F of 950. The Trojan 31 AGM is a little cheaper and has a CCA of 600 whereas the Rolls has a CCA of 760.
My questions are:
1) Does anyone have experience of these makes of batteries in terms of reliability etc.
2) If I fitted all three of the same type, would the CCA of 600 for the Trojan be sufficient for starting a Volvo D-130, or would I be safer going for the Rolls?
Many Thanks
Rick
My questions are:
Many Thanks
Rick
