pvb
Hi pvb
I assumed that being nearly half a vote down on charge would be a bit much and a float of 13.9 for the remaining Lifeline is a bit high; am I wrong? Is there any particular reason behind your preference for the Rolls?
They're all AGM batteries, with essentially the same chemistry and will work with similar charge voltages. Being "half a volt down" won't harm it, you'll just need longer to recharge, but then you will need just as long feeding the lower voltage into any AGM. I have no particular preference; the Rolls as I recall has a longer cycle life.
